Come across it quite a few times Vince, the main reason why I don't particularly like Sachse systems.
May be all right for smooth-running multis, but our harsh, characterfully vibrating clunkers can destroy this type of wiring quickly, especially if no top quality materials have been used and cables are not well supported. Don't know what is currently used on Sachse or Ignitech stuff, but the connectors used in the earlier types also let far too much moisture ingress.
In my experience, poor wiring support creates the most problems, usually only a few centimetres from the ignition unit itself.
The thinner wires are quite sufficient for the low signal voltages that pass through them. Not entirely relevant in our case, but imagine a modern car CAN-BUS system with 3.5km of wiring, if not more, reducing wire guage and overall thickness frees up a lot of interior space and saves quite a deal of weight. Good quality wiring in larger guages can be had with thinner insulation if space saving is a priority.
