michipons said:I changed them shortly and I used this bycicle tool from my previous life, worked nicely... maybe you can built something similar
https://www.bikeshop.es/prensa-para-cazoletas-fijas-park-tool-hhp-2/103919.html?gclid=Cj0KCQjwlvT8BRDeARIsAACRFiWbqauf0J73p4-LLVJNl711fHTACuq6T3scizlpAKuc-_ApV-lzpYMaAp7vEALw_wcB&gshop=ES&ef_id=Cj0KCQjwlvT8BRDeARIsAACRFiWbqauf0J73p4-LLVJNl711fHTACuq6T3scizlpAKuc-_ApV-lzpYMaAp7vEALw_wcB:G:s
Miguel
sfcpiet said:A 5 ton press is man enough for this, surely you have a local engineering shop that could do it It's just a 5 minute job.
Rob said:I have successfully used a long length of threaded studding plus very thick penny washers and nuts ...
Paul Marx said:Got one side in, nearly. The last cm won't go.
Will use thicker threaded rod tomorrow. The 8mm one is stretching, will use 12 mm.
