Swingarm Silentbloc bushes for early SF
Smartv11
Meopham, Kent
I'm not familiar with the ' silentbloc bushes' fitted to the swingarm, are they a generic part, like bearings? If so what size do I need (i guess I need two?)
Whats the best way to remove them?
What tool would should I use to drift them out, any heat required?
Best way to put new ones in?
Thanks, Paul
I had same problem, so I sprayed my swinging arm ,easy solution, powder coating isn t the best anyway cracks off at the adjusters.
Leave em in. A long threaded rod through the swing arm with a large washer either end, which you should do any way to keep powder out of bearing surfaces, will protect them.
Lemon, if your powder coating cracks, it's of inferior quality.
to get then out.......
set fire to them
then you only have the outer sleeve to deal with, hand cut with a hacksaw blade then drift out.
