Yes!Hi
My 1200 is making tappetty noises.
The shims are in tolerance.
On inspection the central cylinder cam lobe is pointed rather than rounded.
I suspect this is the culprit,has anyone had issues similar to this?
Last engine I reconditioned had 2 x A11 Inlet Camshafts in it and damage to No 1 exhaust cam bucket/bore so could tell that the engine had suffered an issue in the past centered around No 1 exhaust valveCam shims staying the same, as previous check, I have a spare inlet camshaft with curves rather than pointed. It looks the same orientation as the exhaust apart from rev counter drive. Is it possible to use an inlet cam on the exhaust until I can obtain one?
