Tarozzi Gear lever
Do you mean an original Laverda or Tarozzi Vince?
Laverda uses radial serrations for adjusting, Tarozzi uses a vernier/pin set-up.
Tarozzi, the name is cast into the bit. I am after the lever that pivots off the footpeg and the knurled footpeg bit. Mine is right-side shifting, but I think they fit both sides of the bike. Just after one, fingers crossed and an eccentric shift adjuster bolt and nut and a gear selector spring.
Have you got a pic Vince, I have some cobbled up rearsets somewhere that were on a 3C and I'm pretty sure I saw Tarozzi somewhere on them.
Wholly Hooly, I finally cracked posting a pic from my phone. A whole new world just opened for me.BTW, the alloy plate with that hole in front of the usual cast peg mount is how I managed to lower the pegs 30mm. I was trying to make it fully adjustable, but you need to allow room for fixing, so that fully adjustable bit didnt happen.
Dont go too hard; I heard from a local who says he has some bits. To be straight, I would prefer just the long lever and toe piece. I would hate to break up a full and good set, as apparently there are no more new bits about. Drop a bike and break it, and not so easy to find.
