G
Grant
Guest
Cam, yours is factory (Tarozzi) and Carlo's is aftermarket (Tarozzi).
Factory wins.
Factory wins.
martymoose said:Full machine shop under my house Carlo, mill lathe drill press you?re welcome to use any time, plus I have a box full of foot peg stuff. I?m home all day Saturday and you need to sort it so you can make the bbq on sunday
cbertozz said:I am also celebrating the wife?s birthday and our anniversary this weekend so I?m out of action!
Dellortoman said:Women are strange creatures.
Tell her it can't be her birthday because she doesn't look a day older than when you married her.
cbertozz said:This is a link to the diagram
http://carlobertozzi.com/pics/IMG_2682.JPG
chrisk said:Drawing is the Same as mine. My pins have a step, not centred. So if you put the pins in arse about, then tighten the locking ring, the arm and the lever go skewwiff. The whole shebang won?t work like that.
I think the sleeve from 12 to 10mm is your best option though, that way everything should be okay, as long as you use 10mm washers either side of the backing plates to hold the sleeves in place.
cbertozz said:Yep the sleeve is the go.
chrisk said:as long as you use 10mm washers either side of the backing plates to hold the sleeves in place.
Dellortoman said:If you make it an interference fit and press it in (like a valve guide) it should stay put.
