Morning Guys, I stripped the bottom end yesterday, was quite challenging getting the engine out of the frame, since the brackets are changed at the rear and the gusseting but nice to just have to removed the lower half and not the Head etc ...
I dont know what the gear is called but it's the smallest one on the layshaft that drives 5th gear output, presumably it is driving in 1st thro 4th.The reason is most likely failed, one tooth only is becuase the main shaft was snapped again...
Reason for that, I rebushed it recently and thought I did a good job however I copied the bush that came out...The correct bush should be full length, mine stops short hence leaving an un supported length of Mainshaft spigot... I have a spare shaft and gear but am willing to buy a gear set to replace this one,,,
Screen is on order and I hope to repair the fairing in time for next weekend too. Lothar 6 speeds sounds nice and could be used but I dont have that kind of money for the forseeable future
Take care y'all keep them bikes rolling !
Just to confirm, the bush should presumably run full length from the step near the seal to flush with the end of the gear ??
