Mactriple
- Wide Bay Queensland
I have just removed the brake pistons from a set of Scarab callipers that I want to restore. The pistons are in good condition but the surface coating has worn mainly outside the piston seal. The surfaces look to be Teflon coated. So:-
Question 1 Is Teflon likely to be the surface treatment?
Question 2 Is Teflon DOT 4 brake fluid resistant?
Question 3 Has any forum member had Teflon coating done and if so what was the result?
Ian
Ian
