Dellortoman
- Tasmania, Australia
Simon Yates said:I do not believe that the pump body has been removed before today.
I wouldn't be too sure about that.
Looking at the photo of the inside face of the oil pump housing, it appears that someone has put those divots in there by trying to force the shaft out before fluking the right position for it to pull out, then had a go at de-burring the damage around the shaft hole it with a countersink.
Putting that oil pump damage together with the incorrect gear timing, chisel marks on the crankshaft nut, spare parts left in the primary cover, and you'd have to assume that a previous owner was a gorilla. Come to think of it, it may not have been an owner. I've seen similar horrors performed by so-called motorcycle "mechanics" employed in bike shops.
I assume there are some raised bumps around those divots in the edge of the shaft hole. You can blame a bloke with a similar name to you, a Frenchman called Sim?on Poisson. He invented Poisson's ratio, which basically describes how a substance will squish out in directions perpendicular to the applied force. Where material has been displaced sideways by the pin being forced into the alloy housing, it will also displace outward from the face.
If it were mine I'd centre it on a lathe face-plate and give the inside face a very light skim around the shaft hole - not going away from the centre any further than necessary to remove raised burrs. But I'm guessing you don't have a lathe.
You'd need to be very careful with any hand-held de-burring tool not to score the area where the pumping happens. Using a piece of file blade or small emery stone risks damaging the inner circumference or part of the face that has to "seal" against the side of the pump rotor. If you slip with a scraper, you'll be shopping for a new pump.
If doing it by hand, rather than trying to file or scrape down any burrs that stick up from the inner face, I'd very gently peen them down with the flat end of a pin punch and small hammer. Then you'd only have to ream the hole back to its correct diameter. A much easier task.
