But he can do good imitation of stupid.
I'm not completely convinced by Clem's theory of larger tyre diameters. Going by Piet's estimate of 3-4 cm clearance under the rear wheel, the tyres would have to be at least that much bigger in diameter to have both wheels planted on the floor. It's certainly possible, but I'd be surprised if tyre aspect ratios have grown that much. It makes more sense if someone had shortened the stand when the bike had low aspect tyres.
Paul, take the stand off, check the legs for straightness when viewed from the side. I've seen them with the pivot tangs bent forward from too much weight on the stand. Can be caused by some heavy handed git using ratchet tie-downs with the bike on the centre stand, or by the bike being hauled back onto the stand with gusto while it has 3 tons of luggage on the rack.
I dunno whether you have oxy and welding gear. If not,
take it around to Clem. Heat up any bent bits and bash 'em straight, build up the worn stops with weld, fit new pivot bolts and all should be well. But if it's still not high enough, ask Clem (nicely) to weld some extension pieces in your legs. The stand legs I mean, not your legs.
