The gear lever RGS does not spring back
I think I’ve found the problem.
Another odd one, though…🤔
When it’s cold, it won’t spring back. But when the engine’s warm, it does!
I now suspect the seal on the gearshift shaft.
When the engine is warm, I reckon this seal is more supple. When it’s warm, the shift lever works perfectly well and springs up and down nicely.
I replaced this seal when I’d taken the left side off to fit a new primary chain and replace the clutch rubbers.
In my opinion, you can’t go far wrong when fitting this seal🙃
Does that sound logical?
Not logical, but plausable.
The primary cover is positively located by the crank outrigger bearing, but can swivel around this to a degree. The pivot pin of the primary chain tensioner doesn't help much to prevent this due to the short length of its' engagement in the cover. A slight misalignment may cause the shifter shaft to bind. Thermal expansion may be just enough to restore proper running clearances.
I'd simply loosen the cover bolts and give the cover a tap up or down to see if the shifter frees off.
I’ve finally had a bit of time to work on the RGS again. I’ve only recently retired, but I’ve never been so busy – now that others know I’ve retired...😉
It was indeed just one bolt in the primary cover, right next to the drive shaft. I loosened it a little and everything’s working fine again now.
Thanks for your replies.👍
