Dave,
If you're getting a spark when switching on/off, the unit at least is recieving power, is connected to ground and the coil conections are most probably OK.
Check your pick-up wiring, probably something amiss there. Position "0" is for test purposes only, if correctly connected you should have a continuous spark at all three plugs (optical pick-up only). For initial set-up and strobing, postion "1" should be used. Once this is set, you can change around the various curves as you like.
What model bike, Dave?
