M MotoJouni Hero member Location Finland Aug 14, 2017 #1 M5x0,75 for Dell'Orto (M5x0,8 is the standard pitch for M5) Also M4x0,8 is needed, not for Laverda (M4x0,7 is the standard pitch for M4). From where I can buy these tools? Edit: Pitches correct now.
Simonr501 Hero member Location Lympne, Kent. UK Aug 14, 2017 #2 A quick Google revealed quite a few hits for those. Not cheap mind! Unusual sizes pushes the price up. https://www.ccw-tools.com/Product.aspx?ProductID=31117&strReferer=search&PPGR=0 Price ?47.18 https://www.threadtools.com/Products/HSS-TAPS/M4x0-8-Tap-Set Price ?170.79 If you are chasing out an old thread then probably just need a 'bottom'.
Gravelroad Hero member Location Central Europe Aug 14, 2017 #3 https://www.gewindebohrer-shop.de/gewindebohrer-metrisch-fein-din-13-hssg/gewindebohrer-5-x-0-75-4022835263166-p-921.html The M4x0.8 is a bit steep, for a simple recut it might be enough to slot/groove a bolt of that size, if at hand https://www.threadtools.com/Products/HSS-TAPS/M4x0-8-Taper-Lead-Tap Regards, Stefan
1200ts Hero member Location USA - Riverside CA Aug 17, 2017 #4 Amazon has a two pack of 5mm x .75 for $10.20
