Far easier and more reliable making cables on the actual bike, using the routing that will be used.
Even with a lot of care and consideration, I end up modifying a finished cable to make it fit as I intend. Just giving dimensions to somebody without him/her/it knowing how the cable is to be routed will rarely yield satisfying results. Bends can shift dimensions to the point the cable no longer fits.
I've been making my own custom cables for quite some time, they've turned out to be more reliable than bought-in ones, and fit better! Outer and inners are available in a variety of sizes, ferrules and nipples ready to fit. Sometimes I need to make a nipple, simple enough with brass rod in various small diametres. Soldering is done after "bird caging" in a soft solder bath, just like in the Venhill vid.
