See pics...Crank gear male tooth arrow meets between oil pump gear teeth w/ arrows together & w/ punch mark on oil pump gear 12 oclock. Timing cam gear is in line w/ mark on head on top. I'm off a degree or two! If I disconnect timing chain & go a tooth back I'm afraid I'll be a degree or two off other side. Can points adjustment make the setting right?
There was movement when tightening crank gear nut. When I turn oil pump gear & crank gear where arrows meet TDC together. Punch 12 oclock on oil pump gear is slightly right of TDC. & Cam gear marks are a degree or two off.
Also the shaft holding the Primary chain tensioner to case has a tapered end. Looks like tapered end goes engine side not cover side...Right? I took it apart & did not take notice which end goes where.
