CLEMTOG said:I have to comment on my learned friend Piets statement above
"Changing final drive ratios has nought to do with closer-spaced ratios in the box. Final drive ratio dictates how fast you can go, gearbox ratios dictate how fast you get there."
This is correct Piet, in part, changing final drive ratios has nought to do with closer spaced ratios in the box, correct, inside the box nothing changes no matter what size front or rear final drive sprocket you use, but the lower that final drive ratio, the quicker you get to fifth gear, so the OVERALL ratios, from engine to rear tyre do get closer, if you gear your bike for a 100KMH top speed it will APPEAR to have very closely spaced ratios in the box, so for track, use changing sprockets can get you an advantage and a big disadvantage.
On my road bike (TOG) I have use 19/38 for a very long time, this is with a low comp, A11 cam engine, it suits me, I like it that way a lot, acceleration is a tad slower, and first gear "taller" as are all the others, but I don't use it in town, and Euro cruising is "relaxed" at around 80/90 MPH on occasions when Andrea came with me it was not exactly the best, but still OK
Laverdalothar said:I think he wanted to express a warning, that with a lightened crank, the danger of over-reving the engine is coming closer when f.e. missing a gear or so.
wonder why we all not just swap our beasts for something that has it all already...:
http://suchen.mobile.de/fahrzeuge/details.html?id=218326447&isSearchRequest=true&zipcode=&damageUnrepaired=NO_DAMAGE_UNREPAIRED&scopeId=MB&maxPrice=1000&makeModelVariant1.makeId=23600&makeModelVariant1.modelDescription=GSXR&pageNumber=1#
at least it's orange... :![]()
nick7 said:Red,
Are you sure about the valve bending thing.Surely if a motor spins up so fast that ,in the case of our old engines, the heavy valves start bouncing as you hita10 k revs sooner than you thought, you will be experiencing fucked valves, bent if you are lucky, smashing their way through the Pistons to the gearbox if you are not. Have had that on a small Honda back in the day...entirely predictable, surely?if you are fitting hollow titanium valves over there with so per duper springs that can take it, let me know?![]()
nick7 said:Red,
Oh no, come on now. That's just talking dirty... Pure filth.redax5 said:no different to installing a Scat crank into a small block Chev and revving it to 10,000 rpm which is what we used to do with a blown small block running in Top Alcohol years ago
never had a valve issue in that engine, had a lot of block issues though
redax5 said:been looking at Maxene as the pilot, she has a bike licence and weighs a lot less than us old farts
just need to get her some life insurance payable to me![]()
Have a shave.Cosi said:I'm on a diet and I have lots of life insurance.....
I have used these these parts with good results in both performance and reliability.
Dingocooke said:They only list rods for MX bikes
