...and I thought if I pretended not to notice it sitting there on the bench while away at work, it would either have fixed itself or gone away. Alas, it has come to pass. The pretending part. It?s neither fixed nor gone away.
I?ve become so proficient at draining fuel and removing the tank, I didn?t remember doing it this time.
On the bench.
Pulled plugs:
#3 looks reasonable (as before), #2 dead as a door nail (as before), #1 is a tad more powdery grey than #3.
Regarding strobing...
Nothing with timing was fiddled.
It ran well on all three pots with the Bosch ignition modules still installed. It also seemed to run well for a very short 10-15 seconds when I first started it up after having installed the Boyer Todd Unit.
Let me clarify.
Back when I first put everything back together with the newly installed Boyer Todd unit and started it up for its maiden voyage with the new system, it started on the button right away and ran smoothly on all three cylinders (10-15 seconds) and then I pulled in the clutch, shifted into first and immediately killed the engine due to stuck clutch plates (hadn?t turned a wheel in anger since early winter...).
Upon restart, It only ran on 2 pots...and has apparently reverted to two pots since then. This even though good spark was witnessed at the plug ends after fixing that dodgy coil quick connector and changing out to new B8ES plugs and 5 ohm caps.
No joy...
Next, thinking the disintegrating pick up wires were worse than I originally thought, potentially having run the length of the pick up loom, I replaced the entire loom with new wiring.
Still no joy.
So, perhaps duff #2 Autoplat coil or duff #2 ignition pick up?? Is there a sure way to test the Bosch magnetic pickups?
I doubt the center Boyer module has gone walkabout.
All three Motoplat coil values (primary) read ~4.7 ohm and plug-cap-to-coil terminal read 16k ohm through new 5k ohm caps.
All three ?Lav Forum recommended? eBay purchased TEC KP03 coils (primary) read ~2.6 ohm and plug-cap-to-coil terminal read 20k ohm through new 5k ohm caps.
Me thinks THEN,
If / when all else fails, perhaps I could try the original Bosch system and see if Anything changes?
Discuss.
