It seems for some, this would be a solution looking for a problem. For me, I have a very real problem with the stock vee-belt drive. The belts don't last long, start to slip and the inside of the drive cover is simply disgusting...
Despite fitting quality Gates belts, I've gone through about 8 belts over the past 30000km, which imho, is a pretty miserable track record. Both pulleys were in generally good condition, the alloy item on the generator showed a little wear, but nothing dramatic. Two generators were fitted during this spell, the first fully overhauled one was swapped out when the housing simply became an eyesore for another completely overhauled item. The first will again be rejuvenated.
The toothed belt conversion is pretty straightforward and I'm expecting it to outlast me... I'll carry a spare on long trips, but that's more for peace of mind. Total outlay was around €90, the toothed belt costs about the same as the vee-type, but will probably be easier to source in the future, vee-belts are slowly but surely disappearing.
