After almost going dizzy scrolling up and down ...........
Archive Stuff .... Page 16 ...... # 301 ......... 1974 John Nutting SFC ........ RCJ 68M ........ Performance graph " for information only " .......
Shows 118 mph at 7200 rpm top speed ..... ( presumably two way mean average , though it doesn`t say ) ....... this was with silencers fitted ...... they reckoned with a racing two into one , 8000 rpm could have been reached , which would yield 128 mph ........ but more as a best one way , rather than mean average , I would think .........
They also say " standard gearing " ........ as in SFC close ratio internal gearing I guess .......... comparing the graph rpm versus mph through the gears , then the results do suggest higher gearing first to fourth , compared a graph for a `73 SF ........ which makes sense ........ top ( 5th ) should be the same , but the `73 SF graph suggests a higher ratio than that for the SFC in that gear ....... which doesn`t make sense , really ..........
But then I gather all 1000 /750`s came with a 19 or optional 18 for the gearbox ........ the SFC rear was 40 standard , with the option of anything between 36 - 41 .......... so who knows for sure what RCJ 68M was wheeled out of the factory with ...........
Archive Stuff ..... Page20 ...... # 399 .......... I shortchanged the 3C(E) earlier ........ best one way was 139.8 mph ...... not 138.9 ......... two way mean average was 133.3 mph ....... ( Which suggests the run " into the wind " was a rather lowly 127 mph or so .... but never mind ....... ) ......
Archive Stuff ....... Page 22 ....... # 437 ........ the 1974 3C .......PPU 40 M ........ 131.5 mph best one way , with a 128.5 mph two way mean average ........ both with a slight cross wind ........
Rider weight / size can have an effect when chasing mph of course ......... Testers were either John Nutting or Stewart Burroughs ........ details relating to them were also given as well as wind and weather conditions .........
John Nutting once told a story relating to performance testing of the then new Honda CB500 Four , not long after he joined the paper .........
They returned from MIRA with the results ....... Editor -in Chief Harry Louis took a look at the figures and said ....... " No , that`s not right ..... it`ll do more than that ..... try again ... " .........
So they took the CB500 back up to MIRA the following day ......... did the usual stuff ..... right hand with the throttle wide open , left hand clasping the bottom of the left fork leg , feet on the pillion footrests , or hooked up on the rear of the seat ........... and they got another 4 mph out of it ............
So Harry Louis was right all along .......
