Sir Sidney Ruffdiamond
- Cotwolds
I have never ground off the rivets without first stripping the components and doing it on the bench/drill stand. I have used heat in one form or other, propane lamp, or the kitchen oven (but only if it is clean enough to eat off) perhaps there is a difference in running simplex chains on the factory supplied two row sprockets over using the outside ones on the earler three row type? I have seen them broken but dont remember much about the sprockets, I know it has happened but I have never seen a broken triplex and I dont think there has ever been a broken duplex reported, the factory race bikes (some) used quadraplex chains with a spacer in the primary chain case and most likley a different end on the crank, unless the four row sprocket was "dished"
Without a "tensioner".I've managed to break a triplex...
Last turn, last lap Sunday afternoon at Spa, 2012. At least I got my moneys' worth of the participation fees.
Turned out it was a 2nd. rate chain, at best. Duplex Iwis fitted since then. Can't actually go back as I removed the outer row of teeth on both sprockets, while I was at it... Happily, the primary cover was salvaged thanks to some clever laser weding.
Here's the crank stub of the works triples that used the 4-row chain, Clem. Completely different clutch sprocket to be seen lower right.
OE cush rubbers were slightly barrel-shaped! Most aftermarket ones are simply cylindrical...Just fitted new rubbers on my Corsa clutch - and replaced the single chains ( new chain had much less deflection both worn similarly View attachment 87730View attachment 87731- old rubbers were a bit barrel shaped - new ones needed a little oil and a rubber mallet - new gaskets from Phill Todd , rubbers from Wolfgang
That engine is the only 1973 SFC engine that I know with a duplex chain, which is almost certainly one of the mods that were done later, most likely by Roberto Gallina. All the other engines that I saw had the traditional triplex chain, in combination with a similar chain guide, but which of course was 3 row and was always made of steel.Only used on the '73 works engines. These also used a duplex chain!
Marnix,That engine is the only 1973 SFC engine that I know with a duplex chain, which is almost certainly one of the mods that were done later, most likely by Roberto Gallina. All the other engines that I saw had the traditional triplex chain, in combination with a similar chain guide, but which of course was 3 row and was always made of steel.
With all the engines that I have seen, there is not much hope left of ever finding one with the unique alternator still present, but I won’t stop searching, still hoping for a miracle.
Marnix
