OK. Dumb question time. I'm about to do the re-bushing of the mainshaft sleeve gear. Making a bronze bush to low clearance fit is not something I've done before. Turning the bush from bronze bar is no problem, nor is getting an interference fit on the OD of the bush. But I might have a couple of other issues while finishing the ID:
My small lathe has maximum thread cutting pitch of 4mm, so that's as coarse as I can cut the oil scroll. Is that too fine? I can't see why it would be a problem, but I thought I'd better ask.
Reaming to size: First problem is that I don't have a 17mm reamer. But that's easily sorted. It's only money. But I'm a little confused about reaming the new bush through the old (worn) bush to keep it aligned. It may not be perfectly aligned because of the wear in the old bush. I assume the reamer has a taper on the pointy end that centres it in the hole to be reamed. The back end of the reamer is aligned by the tailstock, so why do you need the old bush to ream through? Am I missing something obvious in Keith's description?
I've never used a reamer before, but looking at Keith's photo, it appears to have a left-hand helical set on the cutters. Does that mean it rotates the opposite direction to a twist drill? Is your chuck rotating backwards in that photo Keith?
As an alternative to a reamer, if I get the ID close enough on the lathe, would it be possible to finish hone the ID to size using a small brake cylinder hone?
Gotta learn this stuff somehow.
Cam
