Would be difficult to get the profile for the inlet and carb stubs - otherwise you'd have a dirty great 'gap' in the inlet tract. Maybe a smaller ID/oD insert could be rigged up from the same or other material.Hi Andy. Can you find some hose with a braided inter-layer that will do the job? Massively tougher than just rubber alone.
Al the best with the rebuild chap. Paul.
So not std Mikuni, Vince? They do look robust. I use one of that type plus one with the two-stud flange onto the head. Rogue air in the intake port scares me after melting a piston!I use a Guzzi rubber inlet manifold on my 3c with Mikuni carbs, They make one to fit 32mm carbs and one for 36- 40mm carbs, I use the latter. Nice thick solid rubber with preformed grooves for hose clamps.
Carb inlet manifold, 40mm. Moto Guzzi. – Motociclo
motociclo.com.au
As long as you found a reason for the disintegration and it's been rectified!! Good job to have it all back in one piece ... big job!Engine back in frame after new barrels, different crank, two new liners, 3 pistons. Well on schedule for Donney 5th October. What could possibly go wrong now!!!!!!!!!!!!
Hi , Inlet rubber split on No1 !As long as you found a reason for the disintegration and it's been rectified!! Good job to have it all back in one piece ... big job!
Well Haggis I bought her a new set clothes and promised her a slap up meal if she behaves!... will try and get to Donnington tosweep up the detrituscheer you on![]()
Fab! I'll keep my fingers crossed for ace weather, esp so you can give those tyres a good torturing - and get a massive smile on your face. You are certainly due a break from spanner-time.Well Haggis I bought her a new set clothes and promised her a slap up meal if she behaves!
She wants for nothing - new 520 drive chain and new primary and tyres and oil every race etc
