Dellortoman
- Tasmania, Australia
Yes, if you can find one. Not sure why you'd want to though. The electro-mechanical regulators are cheap to buy and pretty reliable.
The existing regulator works by switching the generator's field coil on and off to regulate its DC output. It's quite an efficient system. The generator only works as hard as it needs to.
Most solid state regulators are designed for alternators, so they have a rectifier built in. You could install a rectifier/regulator (RR) even though you don't actually need the rectifier part . It doesn't matter because DC will flow through the rectifier just as well as AC. You might end up without a generator light though. Not many RR's have a gen light output.
You'd have to hard wire the supply to the generator's field winding because RR's don't regulate the field current. They just take all the power the generator (or alternator) can deliver and dump what is not needed. So they are less efficient and tend to get quite warm. That's why they're housed in big aluminium boxes with cooling fins.
I reckon you're better off leaving it as it is.
Cam
Cam
