Twin parts..get them outta here
GaryTT
Qualicum Beach
From the late Helicopter Jim's workshop, we have the following. Make an offer via pm. Located in Qualicum Beach BC Canada.
SF twin parts
SF Head and 1 Camshaft. Some surface corrosion on the cam lobes which would polish out. I have sprayed the head and cams with preservative fluid
Barrels. Corrosion in the bores from not being stored correctly. Dia is 80mm. Sprayed with preservative
Tach drives
Cam tensioners
Numerous gaskets
Generator drive belts qty3
Sachse Elektronik REG5a. DC voltage regulator, New, in box
Several exhaust sets used stock. New Marving chrome 2:1
SFC parts
New headlamp rubber cover
Unused rear fender, new
Lower fairing bracket, chrome
Aluminum battery tray to accommodate a lightweight battery
Bosch headlamp and mounting brackets
