Hey all,
Putting my RGS back together after checking the clutch discs and springs, replacing the chains and clutch rubbers. Here's the issue: I have an unaccounted for shim. I have the one that goes inside the drum and I have the one outside with the circlip. Where does the 3rd shim go? As this is the first time I've done this job I took many pictures and took care (I thought) to secure the parts in their appropriate positions. I don't see another shim in my pictures or the exploded parts views. I did notice there is some fore and aft play behind the circlip with just the one shim. Could there have been 2 shims stuck together for alignment with the crank sprocket? I have not checked the alignment yet. If so would they have been inside or outside the drum?
Thanks,
Charlie
Thanks,
Charlie
