Dellortoman said:If the pumps in the Formula and 1200 are the same, they must be geared at different speeds. Flow rates are different for the same engine speed.
If you had been more attentive young man, you would have noticed the differing drive ratios!
Checked the OR600 part #s, 41 111 305/306 are the respective gears, used solely in this application.
Bob, I too have not found any reference to a special "Formula" pump. Can only guess it was introduced at a later date and therefore not included in the early parts lists. The data I posted was worked out by Mr. Witt and myself many years ago. He had done the triples as well as the 500/Formula pumps, I added the 600 data.
The Zane pumps have 15 and 12 teeth respectively, both 15mm wide. The high-volume 12T is from the air/oil cooled 668, the water cooled 750 shitpile got a slightly decreased circulation volume. Again with the same shaft centre dimensions and the gear pitches echoing the earlier 12 and 15T items.
