Shuggie
- Scottish islands
Pardon my ignorance, but I can't obviously see any stubs on the inlet ports on my RGS to connect my vacuum gauges to....what is the recommended method?
Thanks
Thanks
What!! And miss out on all the fault finding advice here on the forumGood idea to replace them while your at it. Like me they get brittle and fragile with age and you dont want an air leak there!
Thanks I'll take that adviceGood idea to replace them while your at it. Like me they get brittle and fragile with age and you dont want an air leak there!
Thanks for the adviceget the correct id and od tube from a lawn mower/chainsaw shop, silcone hose is more flexible and last a lot longer than rubber and will be hugely cheaper than bought from a Laverda dealer, if you need a new "tee" piece as well then get it from a car accessorry shop, its a windscreen washer component.
Hi PaddyI do the bits Shuggie
