laverdakeith
Mine used to put the wind up my mates z650..... in between engine rebuilds :-X
Keith
Keith
bob said:Can I respectfully ask you guys to stop this shameless thread hijack and bring the subject back onto seals again.
Dellortoman said:Hey Bob, I think I recognise that seal. It's an Antarctic Weddell seal called Marilyn. I remember cuddling up to her on a particularly cold night when I camped out on the sea ice off Mawson Station. She never phoned me or returned my messages afterwards - bitch!![]()
Hisame as Kieth
I fit valve guide seals to inlet and exhaust when I change valve guides, not had an issue yet and have dozens of engines running around set up like that
use custom made Bronze alloy Valve guides and stainless coated valves
works well, so far, no more smoking
I wouldn't fit valve guide seals to a cast iron guide though
0.030 - 0.035mm, our guides are Manganese Bronze alloyHi
What clearance do you run between the exhaust guide and valve if you use seals on Bronze guides?
Hi PietSpub,
Smoke on the overrun is quite common, even though the exhaust guides are NOT worn!
The culprit is the excessive countersunk taper at the top of the guide to supply the valve with oil. I reduce this taper by about 80% and the smoking all but disappears. The pic shows the re-worked guide (can be done in situ), the stock taper has an OD of about 9-10mm. It is now under 8mm.
I have fitted seals to exhaust guides with mixed results. Most engines show no issues at all, one engine in particular has seized 2 different valves on 2 different occasions. I have since removed the seals and everthing is tops! Won't be repeating that in the near future, at least not till I find the real cause for the siezures.
Great thanks0.030 - 0.035mm, our guides are Manganese Bronze alloy
The RGS parts manual shows 3 x 55 120 063 Valve "gaskets" for the intake valves, but not the exhaust valves. With regard to valve guides, there are 3 different guides standard, 1* rise, 2* rise. Presumably 1st oversize, 2nd oversize.Hello Gentlefolk.
Many years have passed since I committed to the FULL and thorough engine rebuild on my 1977 Slater Mirage. I am pulling this motor apart again because it has started to smoke slightly. Rings are new and gapped . cylinder head is RGS with new valves the original has a sizable crack across two valves ......
Here is my question..... The original head has NO inlet valve stem oil seals ..... But,,, when I built the motor using the later head I didn't think and never noticed any valve stem seals.... Does an RGS head have oil seals ?
I thought I had everything covered but I am made of the same material as you lot !
Nice to know yall
Tim
That's correct.The RGS
