Valve Lash Tolerance
lawrence
Idaho, USA
I understand the OEM recommendations for the valve lash on the triples to be .20mm & .25mm for intake and exhaust, respectively.  Shims are not typically available in .01mm increments, so what is a reasonable fudge factor?  Would that factor be the same for all valves?  Would camshaft grind be a factor?
Using a tool like a punch to rub the shims up and down is a good idea. A few years ago I did a bunch of them on an oil stone, but I used my finger to shove them around on the stone. After a couple of hours the tip of my finger was completely numb. Took about a week for the feeling to come back.
