GregT
- Christchurch NZ
That's why shim under bucket setups are preferred. The biggest lift you can safely use on the Suzuki/Kawasaki/Yamaha shim on top is .418in.Surely Laverda must have used an existing car shim back in the day? I can remember Hesketh having shims made at great expense only to find out the motor was designed using British Leyand shims. I once saw a GS1000 that spat an exhaust shim straight through the head leaving a letter box shaped hole.
