Dellortoman
- Tasmania, Australia
I've attached the drawings for A11 and 4C vernier cam sprockets. I haven't done them for the 120 cams, but will do if anyone needs them. The only difference is the location of the timing marks, which is not really important for drilling the sprockets. It just helps to identify which sprockets you have.
The tooth spacing is 12o and the hole spacing is 25.71o, so the indexing increments at the cam wheel is 1.71o (one hole shift - two tooth shift). That equates to 3.42o at the crank, which is quite a coarse adjustment, but there isn't enough room on the cams to drill more holes. Fine adjustment between the 3.7o can be obtained by slotting the holes in the camshaft flanges. A 1mm slot is sufficient because that gives near enough to 4o change at the crank, so you don't need to remove heaps of metal.
Note that if you have A11 sprockets on 4C cams (as I did) you may not need to drill more holes. I just flipped the inlet cam over and slotted the cam flange holes to get them right.
Phil Todd has said on several occasions that the bolts won't slip in the slots. This is also confirmed by ny experience. I've done about 3000km since slotting my cam flanges, and the timing has stayed put. One thing I probably could have done (but didn't) is loctite the bolts. But they weren't loctited originally and they do have lock washers anyway. I'll check them next time I do the valve clearances just to make sure nothing has come loose.
Edit: Hole set 0 on each drawing is the original hole set. Sprockets are marked "A" and "S" for inlet and exhaust respectively (Aspirazione e Scarico)
Cam
Cam
