various bits
CLEMTOG
various bits for sale having a general clear out (it will take years)
rear disc 180 type swing arm , also fits SF3 bare metal and grit blasted for conversion that didn't happen£80.00
rear footrest, not genuine, but a good con, £35.00
Jota genuine Brevettato bars in need of a little TLC, centre section slightly bent not brill chrome etc £140.00
750 genuine sump plate with welded on drain boss and plug £55.00
180 type triple inlet manifold 32mm intact, no cracks genuine £35.00 sold
750 type triplex engine sprocket (seems with small mods can be used on triples) £45.00
post anywhere at not much more than cost
clemlav@tinyonline.co.uk
0044 (1) 959 532316g
and more bits
1000 early type 180 primary cover, with "1000" logo and an added chain inspection cover which is a 750 tappet cover £180.00
750 set cluych plates and pressure plate inner and outer £80.00
1200TS, Jota 120, RGA speedo unit £40.00
very early and rare oval bung type clutch.sprocket cover with mechanism, wont be repeated, £250.00
750 sump strainer gauze £30.00
180 triple sump strainer gauze £30.00
ship anywhere for not much more than cost
Hi Clem,
Can I take the intake manifold please (180 type triple inlet manifold 32mm intact, no cracks genuine £35.0)
Pm me the details regarding postage etc....Paypal okay?
Steve
what I say or what I sell?
as many know I have been confined for a bit, and am a bit surprised at the lack of interest, so all is still available, as the first two listings (but not the manifold) and I invite you all to make any offer that you think is apropriate, silly or otherwise. You never know, I might accept (or not as apropriate)
I'm not a bit surprised at the lack of interest Clem.
It's a declining activity, riding Laverda motorcycles.
Hi CLEM.
"very early and rare oval bung type clutch.sprocket cover with mechanism, wont be repeated, £250.00"
Is this part valid on later models?
I am thinking of leaving the hydraulics and definitely becoming a true laverdista;)
Regards
thanks, I am not entirely sure what your question is, this oval (or bean) shaped holed sprocket cover/clutch mechanism, will fit onto any 750 SOHC twin (Breganze era) it was the first type fitted in 1968/9 and probably got superseded because of the cost of the odd shaped rubber bung, but who cares anyway and if you saw off the lower triangle and clean up the the rough edges will also fit any 180 triple, I always thought it would be a good addition to a triple drummer,(just me not anyone else) but by 1972/3 the round one was made available so that model never did have one, I just saved it when it became available.
Are you considering fitting this to a Zane era bike? possibly a water cooled one? that will not work.
Not sure about the rubber bung cost Clem, those bean shaped bungs were also fitted to the airboxes of the bikes with the horizontal air filter. Two per airbox, if not more.
I have a couple of bungs Paul if you need them for 750 or 125, might get me a part exchange discount on the wheels of maybe 100 E's or so and I don't mean money
but then again you are a good boy now I am sure
