Various RGS/SFC 1000 bits
Clumber981
As you can probably guess from the adverts below I am clearing out the garage .  Amazing how much stuff you accumulate over time for those 'just in case scenarios!  This lot (plus FJ1200, XT600, Ducati, BMW and KTM stuff) is just taking up too much room in the manshed ... so listing here we go....!!
-Brand new SFC1000 speedo drive cable. PLUS 5 inches over standard to allow for different routing (Venhill, see label) ?20
-2 repro rubber caps for SFC 1000 M1R fork (fits over the schrader valve) also includes the two old OE items (one damaged where valve wore through) ?5
-1 set (4 off) spacers for SFC1000 front mudguard 'bridge' ?5
-Pair RGS side grab handles (anodised black but came out grey!) ?8
- RGS choke lever (plastic lever) ?10 SOLD
-Pair RGS exhaust hangar rubbers Some slight cracking around metal insert but studs are solid in place when loaded ?16 SOLD
-3 off Bosch ignnition boxes and mounting plate ?60 (all working when taken off bike)
-2 rear engine/frame mounting bolts (cleaned and new zinc plated)?10
-SFC1000petrol tank fillers. (2 off) Both have suffered damage to the alloy caps but only extends slightly down the knurled sides (tried to show in photos). Could be welded/Repaired. Steel threaded flanges are fine. ?40
UK Postage  will be either large letter  (?1.50 )or small parcel (?3.70) depending on the item.  I will use the cheapest.
if any overseas interest please contact me first so I can check costing.
Cheers, Ralph.
Ralph,
You forgot to mention that those filler caps have been around the Island a few times
https://www.laverdaforum.com/forum/Smileys/SoLoSMiLeYS1/grin.gif
N
Cheers, Ralph.
Hi Ralph, are the SFC tank caps & flanges still available? Cheers Scott
