Voxbell connector wanted
This can be found from many vendors by using the DIN standard.
I think it is DIN 46346 connector, the size needs to be defined additionally, but I guess it may be 6.3x0.8 or 1/4"x0.8, and the cable size.
Ones made of phosphor bronze are better than brass.
DIN 46346A has a sort of tail
DIN 46346B is without the tail
And then you need the casing for the connector, but the vendors usually have them.
-Jouni
It’s really the casing to be precise, any female spade connector would work but just wouldn’t look right bare. Most of the modern casing are soft plastic, the older ones seem to be a rigid plastic. I feel sure someone has a draw full !?
I think then you need to take a photograph if you need as similar as possible.
These are connector manufacturer related products and Laverda used ones that were available when the cable set was manufactured.
Don't know how many alternatives there actually is on the Laverda cable sets.
-Jouni
