Wanted-Twin Horn bracket 1976 3CL-Ceriani Fork
Graham
Cumbria
My voxbell horn bracket has broken in half. Before I set to and make one does anyone have one they would be prepared to pass on?
Thank you, Graham
Hello Piet,
Thank you for you reply about my stricken bracket. Yes, I mean the twin horn bracket that sits under the headlight, if there's any doubt I can ping you a picture across. I'm not an expert but I think that this bracket might have been fitted to the 750's as well? I'll measure the approx distance of centres of the bottom yoke mounting holes and send them across to you if that helps?
Many Thanks!
Graham
Hello again Piet,
I think the part number is 21115109. I have measured the D O C of the mounting hole and they are approximately 36mm
graham
Hello Eric, yes this is the part that has sheared. thank you for suppling a drawing for the component; I could always make one if need be. I've done a little research and I can probably buy a replacement, I'm hoping that SFC Peit will be able to find me one so I'm waiting to hear from him. Thanks very much for taking the time to post the picture-much appreciated.
Graham
