Washer size Alpino 500 front wheel
It may seem an integral part of the speedo drive housing, but it was/is available seperately. About 1mm thick and fits into the recess of the housing and normally stays put. It is simply a bearing surface for the step in the axle to prevent mauling the soft housing alloy.
65 years on this dirt and girt and I had to google ‘mauling’ in that context.
Mostly I’ve only heard it from females “Would you stop mauling me” …… which makes sense in both forms I guess.
Gees Chris Mauling is a Rugby Term. Mauling and Rucking.
A rugby maul occurs when a ball carrier is held up by one or more opponents while one or more of the ball carrier's teammates bind onto them, forming a standing, moving pack of at least three players. Unlike a tackle, players must remain on their feet to drive forward, aiming to gain territory or score.
World RugbyWorld Rugby +4
Key Aspects of a Maul:
  • Formation: Requires at least three players
  • Binding:Players must be securely bound with a full arm, not just holding on, and keep their heads and shoulders above their hips
    • Movement: The aim is to move toward the goal line (often a "rolling maul").
    • Duration: If the maul stops moving for more than 5 seconds, the referee may award a scrum to the team that was not in possession, or demand they "use it".
      RedditReddit +6
Usage Examples & Scenarios:
  • Lineout Drive: The most common attacking use, where a team catches the ball in a lineout, forms a pack, and drives towards the try line.
  • Territory Gain: Used to drive opponents back and gain ground.
  • Drawing Defenders: Used to commit defenders, opening space for backs elsewhere.
    RedditReddit +3
Synonyms/Related Terms:
  • Rolling Maul: A moving, rolling version of a maul.
  • Driving Maul: Another term for a pack driving forward.
    TikTokTikTok +1
Rules to Remember:
  • Defenders cannot deliberately pull a maul down.
  • Players must join the maul from an onside position (behind the last feet).
  • The ball can be passed backward through the maul to a player at the back.
  • If a player falls to the ground, they must release the ball immediately.
    YouTubeYouTube +3
  • Tackle, ruck and maul - World Rugby
    The maul. A maul occurs when the ball carrier is held by one or more opponents and one or more of the ball carrier's team-mates ho...
    World Rugby
  • Could someone explain the maul for me? : r/rugbyunion - Reddit
    So essentially a maul is like a standing version of a ruck , or even a mobile scrum , insofar as both teams have to remain standin...
    Reddit
  • Rugby What is a Maul
    A maul involves setting up, and players must maintain balance and stay on their feet when joining. A maul is formed when a third p...
    YouTube·qprmarsh
    2m
Show all
