What are these???
motoddrob
S/W Australia
Found these in one of the boxes of parts with this 81 jota motor I reassembling. They're new and were in a post packet from Wolfgang.
The nylon washer is 40X25X2mm. The cupped washer is 32X24X1mm.
Could be from the frame as that's in pieces as well.
Any ideas??
Rob
if you have the bearings out of the swingarm, you insert the cupped washers first, then press in bearings
nylon spacers are the spacers for the swingarm
that is what they look like to me from the photo
+1
Thanks Red,
I wonder if he brought new S/arm bearings then. I converted my SFC to needle rollers so I should've known, but that was 25 years ago and I've forgotten more than I can remember :-\
I can't find the timing marks on the motor. A Witt ign. has been installed, probably not set up and there is a couple of, I asume, original ign backing plates with timing marks on them as well as the rotor in the box.
I ended up using a timing wheel to reinstall the cams.
Cam, that dead stop is brill!!
