Poffer said:
On a more serious note - try and avoid heaving the triple up on a block of wood.
I reckon Steve should knit little booties for the centre stand feet if he's that precious about marking the floor
One thing I find a bit awkward is putting the bike on the centre stand when it's on the bike lift. You need to get up and stand on the edge of the lift table while heaving the bike onto its centre stand. It's all a bit precarious and could go pear-shaped very easily. I have visions of me lying on the floor with a bike on top of me. Or even worse, the bike falling off the stand the other way and setting off a domino effect with the other bikes in the shed.
This doesn't appear to be a problem for TTW as Steve hasn't provided him with a bike lift. Made the poor old bugger kneel on the concrete floor.
Anyway, I came up with an idiot-proof and non back-straining method: I now have a piece of rope hanging down from a ceiling truss in the garage, above the back end of the bike lift.
The procedure goes like this:
Wheel the bike onto the bike lift and secure the front wheel in the wheel vice thingy. Once the clamp is tight, the bike will stay put without having to hold it.
Jack the lift up to its highest position.
Tie the rope to the grab rail on the back of the bike (or something else solid if no grab rail) so that there's no slack in the rope.
Slowly lower the lift. The rope holds the rear end of the bike up as the table drops away from under it. The rope will stretch a bit as it takes up the load. You may also hear creaking from the roof framing if your garage is anything like mine. (Creaking is OK. Cracking isn't)
The bike is actually quite stable dangling in this position because the front wheel is still clamped (bike pivots on the front axle) and the rear end is suspended from above its centre of gravity.
When the lift table is low enough so that there's enough room under the bike, flip the centre stand down.
Jack the table up again so the weight is now on the stand.
Don't forget to undo the rope! (and hitch it up out of the way while you work on the bike).
Using this method made it a dead easy to put the Kawasaki 1300 behemoth on its stand. A hard enough job on a flat floor (300kg bike).
You just need to be confident that your can hang a couple of hundred kilos from your workshop ceiling. Don't try it if you have a little tin shed with flimsy framing!
