We have a couple of suspicions as to why.First culprit might be the Kehan CV carbs.So I am going Reds Flat slides,the 2nd might be me and my fiddling with the static timing.I know just enough to be dangerous.What I did was use a dead stop to find TDC on No1,drew out a circle the diameter of the flywheel and marked the distance 36 degrees and 12 degrees scribed at.Marked the flywheel and checked this with a timing light.Then I moved the timomh to suit or as close as I could considering the Kawasaki alternator blocked access to the alan bolt for a tiny bit.I then used John Wilson's curve No 3.It felt better in the mid range.I then tested the bike on the biggest hills around in 3 gear giving it fist fulls,didn't hear any pinging.Maybe I need a Honda boring with factory sealed Injection and timing.Anyway there is a lot more access to the new Sach Ignition with the potential for damage so take care out there.So if you cannot read plugs these days is a trip to the dyno the only safe was to detect Detonation,can it be detected before it destroys your engine.Seems from that article earlier in the thread,Detonation can exist in mild forms for a while and not do damage,preignision takes seconds to damage engines.I always try to use the highest octane fuel I can but have used 95 when I cannot get 98.These numbers are different over the planet.The article said Hemi style heads were the worst type for Detonation and I think thats Laverda style head,Yes?
