I think you are right. The effect of inertia does it actially for two times every revolution, the piston speeds up and slows down every 180 degrees. The total result is the combination of both inertia and gas pressures.Gravelroad said:You're missing out inertia of piston and conrod which is of considerable figures, and I'd guess especially at higher revs and small throttle openings not fully compensated by gas pressures.
Some Laverda rods are coppered for reducing notch sensitivity, which is of course softer and then more easy to scratch than the steel under it.
I once did a very littlebit mathematical modelling of SFC 1000 crankshaft. The piston changes it's direction very rapidly at TDC but makes smoothened direction change at BDC. I think this conclusion is made for better gas exchange but leads to bigger forces at TDC.
