Mikal
- Ontario, Canada
New to Laverdas, (1975 3C) new to this forum (thanks for having me). I am sure this has been asked but I can't find it so reluctantly I turned to ChatGPT for an answer on what compression numbers are good. Coming from the Ducati world they seem low:
Condition | Approx psi | Notes |
“Perfect / new‑ish / ideal cylinder” | ~ 125–135 psi | Around spec (i.e. 130 psi) |
Slightly worn / “good” | ~ 110–125 psi | Still usable, though less margin |
Borderline / suspect | ~ 90–110 psi | Might show loss of power, suspect wear |
Too low / needs attention | < ~ 90 psi | Likely need top end work, valves, rings, head gasket |
