What's this cylindrical thingamajig in my wiring harness?
  • Thread starter Thread starter laverlesmains
  • Start date Start date
L
laverlesmains
Guest
I hate wiring, so with any luck it's an old unstable blasting cap.....
Thanks, Tim
It's the engine stop relais.  Needed to switch off the CDI.  Simply grounds the CDI to put out the sparks...
Get yourself a decent ignition system, then you can throw that thing in the skip.
thanks Piet..
can't find it in the wiring diagram.    a bunch of wires run to the connector block.  and then there's one other - does it run to positive or ground ?
TIm
It's wired to the ignition switch as well as the stop switch in the throttle grip body and the CDI.  Switching to "off" will ground what is basically a battery independant magneto ignition.
Got it.. thanks.    Should it be connected to the positive terminal of the battery, or to the negative?
Tim - if you've got a wiring diagram it's referred to as the "emergency switch relay".  The live connection to the relay is fed from the ignition switch / kill switch via that connector block you mention; the earth goes to the frame (or battery negative).  If you connect the live feed direct to the battery positive you'll never be able to switch the engine off..!
Get yourself a decent ignition system, then you can throw that thing in the skipon to ebay.
Sorted it for you :D
                          Dave
Perfect.. thanks.
Tim
