So we're rebuilding the engine on my '73 SF1 750 and found the crank slinger was rubbing on the bottom case. By pushing the crank tight up against the ball bearing end and massaging the slinger a little it not longer touches.
But now i'm thinking. How do you decide where's best to put the crank as a shim behind the ball bearing would allow it to run more centrally but means we've got to decide how thick and then send it off again.
Heres a picture of the other end thats a 1.27mm gap. How critical is primary and cam chain alignment?
