Dellortoman
- Tasmania, Australia
I'm impressed that you can tell what colour the frame is by the smell of the exhaust.
Grant said:Multigrade mineral oils have long chain polymers added, such as EVA (ethylene vinyl acetate). At low temperatures these molecules curl up tightly and so don't impede oil flow. So the oil can flow more easily at low temperatures.
As the temperature increases these molecules uncoil and entangle with the oil molecules, thereby increasing viscosity.
Oil shared with the gearbox has a very hard time as the cutting edge of the gears shear the oil so the viscosity reduces as the long chain molecules get chopped up.
That's one of the reasons why it pays to change oil regularly on our bikes.
Not sure of the chemistry of synthetic oils but I assume it is broadly similar. The manufacturers claim much longer usage time before replacement so maybe they have found a way to avoid chain scission by the gears. Even if I was using synthetic oil in my Laverda (which I'm not) I would still want to replace it more regularly than 10,000 miles or so.
I usually end up replacing the oil after 1000 to 1500 miles. Sometimes even sooner.
Ah, noGrant said:Not sure of the chemistry of synthetic oils but I assume it is broadly similar.
No, but oil technology has moved on a bit ... 8).alan james said:... or are we saying that the manufacturer got it wrong?
alan james said:Any good 20w/50 standard oil will do the job in these old roller bearing engines. Change the oil every 1500 miles and clean the oil filter every 6000 miles, the engine will then outlast you.
Grant said:I suppose the factory assumed normal ambient temperatures for Europe, but if used in more extreme conditions (way below zero) then perhaps the oil quoted by them would not be ideal.
But maybe they also thought that folk wouldn't use the bikes in mid winter.
SimonR501 said:Oh, in my experience I can barely detect the difference between a C3 bearing and a bearing with standard clearance. They aren't THAT loose.
andrew_uk said:.....It gets changed every spring at around 1000 - 1500 miles. .....
Basketcase said:I always understood that C3 bearings had the same "installed" running clearance as normal bearings.
They are just designed for the outer race to be a tighter fit in the housing than normal. This crushes the outer bearing race to the correct running clearance.
Rob
