- Auckland, roughly
My mate who was an aircraft mechanic for our RNZAF taught me how to lockwire the sump plug several years ago, just after he’d helped me helicoil it…
No manafacturer I can think of lock wires a sump plug or fits metal valve caps, in fact Schrader make plastic ones.Shit happens, the story went just after they released the modern MV one on a track day lost an oil filter on the main straight. That got my attention. BTW my 3c had a race history, or at least it was used as a pratise bike so I head years later. Found a few drilled bolts on it. Another story I heard had a local Guzzi racer having a rapid tyre deflate on a track day, cause a rubber valve cap. Replaced mine with metal after that.
It`s that Mr Sod you really want to watch out for ....Us ex-racers are terrified of Mr Murphy though.
It is here.It`s that Mr Sod you really want to watch out for ...............
BTW .... as for drain plugs ..... Is it the case that the regulations for some race series ( maybe the IoM ) say the bottom half of a fairing must be able to contain and hold the engine oil , in the event of a drain plug coming loose , or more likely , an engine blow up ? ....... I`m sure I saw that somewhere .........
So it is ....... Sorry , I missed that ! .....It is here.
Do you lockwire hand tight spin on oil filters too?![]()
If you cannot find a hose clamp or two, just hammer a long spike through it that can catch on something to stop it screwing all the way off.Where is the best place to drill a couple of holes in the sheet metal to accommodate the tie wire?![]()
I was making a joke ….. clearly lost on the translation.If you cannot find a hose clamp or two, just hammer a long spike through it that can catch on something to stop it screwing all the way off.
So was I in suggesting lockwiring such a filter...mostly just done up hand tight. No harm in lockwiring your sump plug, though as Clem points out, personally I dont have the skill..looks like an art....but if it were a significant risk, all bikes would come lockwired from the manufacturer. They dont, and it isnt.I was making a joke ….. clearly lost on the translation.
