To get the drilling pattern right you just need to flip the disc!
I remember back in the 80's there was fierce debate about cast iron vs stainless discs. CI came out top because of wet weather performance.
That was until sintered-metal pads came along and that changed the game completely.
Advantsges of Stainless:
1). Coupled with sintered-metal pads has a higher coefficient of friction.
2,).Is more resistant to warping.
3). Highly resistant to wear.
4).Tougher and less likely to crack than CI.
I bought some stainless discs from Stein Dinse, they look almost identical to the original CI discs with same drilling pattern and fit beautifully. I believe they are also Ducati Bevel fitment!!!!!!
https://www.stein-dinse.biz/product_info.php?products_id=2024
The stainless discs above are thinner than the cast iron original, which is one presumes a product of better warping resistance. They start off at 5.75mm and minimum thickness is 5mm. CI starts off at 6.35mm and minimum thickness of 5.7cm.
I do like Cams warp theory, makes a lot of sense. Although worn discs are more susceptible to warping.
Anyway! My front discs never get really hot. Maybe I should do more 'banzai' stops?
