I agree, that one change can almost "force" the next. If the bike else is standard, Ikons are good shocks and an improvement over the original ones, no doubt. If you are planning to transform your bike into an almost modern riding feeling, this as said before will need you to modify every single step. Forks - at least speaking for my 38mm Marzocchis - can be made to work very good, but they need at least some attention (and in my case a stabiliser), too. Went on that journey years ago, coming from worn out Marzocchi AG Strada to Konis at that time. felt the bike to improve dramatically, but now the fork was to soft. changed the springs, the oil, pre-load and installed the stabiliser. Was OK for some years. Then I changed to box-type swing arm with needle bearings, which improved the riding also. Then Piet introduced me to the GSX-R rims. Now the whole setup needed to be much more sensible and the Konis simply were not doing a good job here I felt. Changed to YSS and all of a sudden, the bike handled like a good bike from mid 90's! No problem to keep up with my wife's brother's VFR750 (RC36) anymore! Handling is a dream on that bike, no where near the way it handled when I got it 1992...
So - will Wilbers be good to your bike? Yes, they will. Will you make the most out of them? Not without other modifications.
