This is w/ the Bosch Headlamp. See pics. Ok it has what I call the drop key. Was last running in 1988. I always turn the light on before firing my Gt which also has the Bosch Headlamp just to be sure I have power. The wires from Key switch to headlamp is a good place to start. 1 Wire to headlamp connector are on 8787 is disconnected (not sure where it goes) & at least one was spliced w/ a different color wire. Red wire is connected to 2 wires. I also bought new Lucas switches a couple of years ago. They need to connect inside the headlamp as light switch has brights. This is a start. Then I have the Schematic from the green book. I assume the big Dome diagram is the headlamp just below the clocks. The original fuse box on the side of 8787 has rust so I put on the one from 17580 which is from the Sf2 but they are the same except for the connectors.
I do not need the Kill switch or the Blinkers. & what is that Lucas box in the Headlamp cowling? (img 445) Is that some thing I need connected?
