ScorchLaverda
- Brisbane
Hi there
I am busy doing the wiring loom for my bike. Basically starting from scratch... I am using Honda VFR switch gear and the Honda VFR starter relay.
I have done almost everything (standard way, not using a bunch of relays). I have not wire up the indicators, horn, brake switches and neutral switch... I wanted to test if the bike will start but nothing happens to the s/relay. If I take the wire from the starter push button directly to the batter the s/relay kicks in like it should. Its like there is not enough power from the starter push button to kick the relay over...
Is it because the loom is not complete yet?? How can I test something? I think there is only about 2 Volts over the kill switch. Is this right or am I doing something wrong?
Please help..Thanks
Please help..Thanks
