WITT wiring match up
I was cleaning up one of my 3C's and the wiring harness from the WITT box is quite short and the blue and yellow wires pulled out. I know where they go but I don't know which way is which. They match up to a white/red/black wire and a white/black wire. If I am not mistaken then I could try just connecting them and if I am wrong then it won't start so then reversing them will cure this. However, I would like to replace the connection with a modern waterproof connector and that would involve soldering some pins and once done would be a bit difficult to reverse. I can't find a wiring diagram that addresses the wiring for a 1974 3C.
Thank you for any help.
Jim
27AM_1JLENtJbbVJ1JkfRabNA5Xv0kskoKMCvdS0jUFHCKkMP0S1XBZxMoNn4sXmJDpLB6YzNkK8pQljynjIHBgAkr8DB9zB3Po4oHvKV-VY7lHygBdu6THD3_yO1RiWz0yBPFvP8SjrRQnU-EUDpa-fAKGjFnTYFh_sWejhRxXMUCjaMllpX50KPT8KbyZhwRL4Qzlh8aIiv6D-mOetC7FzAtFuldUlAckZzDaGrQ2IVshr6P9SjdYGjy5jcYEWn0xWAdk-h6Ncp-IYt0rWRTJ8ZhG85wawMUsJe0XPm2af3VeAPpJVwPYppYeUYpEqvHdUsSnIKqk9X8YpK7Tgnl8sUDq77dvOehPDb0l3equHyMiMU1Am_hSH8UNoRzRktVlycM1eKD_kd7xC4NRt411yYaIVidy_FtSvgGYoNME9bZ6V314nYoN6XW545L4m9x1g4a9RbLf5LVGLNUTj18KQTo68B70nRuAjYgaa19gIeqDQhKKAwu9PX0loV3I0HdbcWLWPZfxCHMn8zNRlq0hquL-6TaHaViEffJNiOwmuRx1K0Qzo4_95yC_sT-mUGTjPcfEGCNwvn_Np57464p2TZUGcv2KQVqHjDZ5lrxJf9Iw1IXb7-jy_v60hn78UF28gjO-oKFLaBgYM6nqPXRHxo1kp0Cir06rtfhHytJROFJLa7KD5Oell4ZSTOgNAyklT-IrymtmwmIJ9TzAd4pvcyQbFkvYW5SHqyYG4fcgHS_czVb91KAE8xYUf4P6y63ICVyGXMAIR9ZNBuI02pofwSCrnZyM1Ph1wdakVfq72OVbOrv8IzZiBItmWf6h7oftF5xocE1q1FaYOkXmimxd5jFceC4omWVyB47YPSvIJpBjqZIY4x1GzXKfmmxgAHlu-7jyvMnlDfETZSC7cPCfEN5DNR8hGkZcDGBECfAoA8w=w1097-h617-s-no
_6iVw0zyXyeO8cqDjy7-jCV537YL_94IlVma7xo8kqMQtKuOi94Qu91GTo2Dz0mlNGE-SsiL-bHccJqmDBS0wkBLHuJLfuVe50iLaofx_M-Gq8AIipqEuXwH__S_4R_1oOSWdKruPemVnlwIdjsQQOz389s1drhjSQhRiWp3IKq1a--DRKJH-P2h9_OfKKNf9PvzdBJ5DdRHvMU9fWD61bliWLs7PxmReaaRa77al4SnTFz0izwvkxYNYsjYGunl363yqk9vpKmARi6HstwQ8uLoEpsLWVZa-yBSPXZW-9f73CQI28qEpjBt-7Iz80jVXjJt5zjJhr3wH6_Nwd-U2Y0nWMqss65Vth181AoOhJogylN9IGCaO3g1-m1Ma29WUnesr9rytWqJSY4hiEc6PsYZxOF4vuouFEKZ-VYtU8EXEPKyBZsIUATUYrBNCKxtVlpEHHdgyMOGQW3-Q8o_hp5bCugpLcQcPhbLNKiZCeipfi2I5j5k_9OpWXNwtICASttRkuaLnyfSuImD5yM6rLBChPTQmWCUwuUb66q7GWk7D2qbFvv8dDpOSIfq6A2qkjEUs6v8DNJCT4T7cwhl8Gd0leLgkYGNjCLYs438772K54lEk3b67Ui--n99XaIow1I9hc9Skuh7Kw5z7suT5dcIfjrtNLRrkeB2Y-9W6V6PykmyesgrvrOpKx8AJlwR3tfi4zBz_WxEz4XzN5rPuCGjoejcE5Gn17XxPCqUC51alW7PuRM8aLzgOMOxNqnqMVfHvuXoxPspnabMyiJF3nJ7JhRa9IpCyPNUbVip7I2lPmuklkZ4gWkLefIv6nXVP3ETScrO_lukwHGAV_A1xehMnPyr04GFJYYXLgj_qW9Gnu5ikfar9Q12UaFEiOlV8vDZFltIRFTSwrPImsEs1VhDirry4B0TFIIrkdTzV6s93Q=w1097-h617-s-no
